Pre Heat Error
Roy
 Roy
(@roy)
Pre Heat Error
Hello,
Is there anyone else getting the Pre Heat Error if you use different temperature settings on different filaments loaded to the MMU2s?
If all temperatures for the 5 Filaments are the same, I don't have any problems. But if I have one filament with a different temperature (which is pretty much normal) I am getting the above mentioned Error message which I can just release by pressing the reset button.
This is making the MMU2S useless in my opinion.
Of course I am using the latest software: 3.6.0 for the printer and 1.0.5 for the MMU2S.
BR
Roy
Opublikowany : 17/03/2019 3:59 pm
