Possible to share filament profile between single and MMU2S printer profiles?
[Rozwiązany] Possible to share filament profile between single and MMU2S printer profiles?
Shipe Design
(@shipe-design)
Forgive me if I'm missing something obvious...
I had a large collection of custom filament profiles before upgrading to MMU2S. They now appear only when viewing the MMU2S Single printer profile, and disappear when using the MMU2S profile.
I assume there is a way to edit the profile to allow it to be used in both circumstances, but I'm not familiar enough with how it differentiates between them to manipulate it.
Thanks in advance!
Best Answer by Shipe Design:
I solved this on my own. Under Filament Settings > Dependencies > Compatible Printers you would assume that checking "All" would handle things. It doesn't.
Uncheck the "All" box, then the "Set" box beside it will become available. Click "Set", then check the boxes that correspond to the printer profiles you use.
Then you're in business.
Opublikowany : 15/08/2019 8:10 pm
2 ludzie polubili
Shipe Design
(@shipe-design)
RE: Possible to share filament profile between single and MMU2S printer profiles?
Opublikowany : 16/08/2019 1:06 pm
