Poor adhesion, bed leveling?
thedevilsjester
(@thedevilsjester)
My MK3s used to work flawlessly.
I have been struggling for the last year or so to get good bed adhesion.  I have used multiple build plates (the textured and the smooth) with no real measurable difference.
It looks like my bed is not level.  The automatic mesh bed leveling is woefully insufficient (its never even close).  I can get somewhat close by manually adjusting the z height and the four mesh values, but its not perfect (I still have high or low spots) and takes forever to get setup right.
What would be the best way to diagnose what is actually causing the machine to be so far out of level?
Napsal : 03/12/2020 5:01 pm
RE: Poor adhesion, bed leveling?
Are you running current firmware? If you haven't already, enable 7x7 mesh bed leveling. It provides far more accurate results than the old 3x3 procedure.
Napsal : 03/12/2020 9:52 pm
1 lidem se líbí
lcdguy
(@lcdguy)
First i would do the following.
1. As recommended change to a 7x7 instead of 3x3 for the mesh bed leveling.
2. If you are using octopi/octoprint there is a prusa leveling guide (it's more geared towards the nyloc mod, but can give you an idea of how out of level the bed is.)
3. Consider implementing the nyloc mod (basically replace most of the spacers with washers and m3 nylock nuts, i did it recently and gives you a lot more control on the levelness of your bed. Before i installed the mod my bed level variance was 1 and now it's around 0.06.
4. Verify the pinda is still the correct distance, it should be about the thickness of a zip tie (around 1mm) between the probe and the heated bed with the nozzle just barely touching the bed.
It might also be worth while to run through the xyz calibration test to make sure everything is still square and nothing has worked it's way loose. IN my case my z offset is around -0.750. Also this is using the smooth steel sheet as i don't have the powder coated one.
Napsal : 04/12/2020 1:09 pm
thedevilsjester
(@thedevilsjester)
I have used the 7x7 and it didn't really seem to give me better results (or at least they were not better to a degree that I noticed a difference).
I do not use OctoPrint
I will certainly look into the Nyloc mod, I just wonder why the bed is so unlevel _now_ when it didn't used to be.
I have verified the pinda many times, but its difficult because the zip tie would be a tight fit on the left side and not even touching on the right side (and a less severe, but still quite noticeable front to back)
I also do the xyz calibration fairly often, I get regular clogged nozzles, a separate issue; but it means I have to disassemble the hot end often and I always do a full xyz calibration, pinda height adjustment, and mesh leveling calculations each time.
Is there a way (without Octoprint) to see exactly how level the bed is?
Napsal : 04/12/2020 5:31 pm
jsw
 jsw
(@jsw)
I think things like switching from 3x3 to 7x7 leveling, as well as many other minor tweaks, do not do much individually, but cumulatively they give more consistent and better prints.
If you think your machine is 'dimensionally challenged', you might try a technique discussed a while back where a known-accurate straightedge is used to carefully measure, and adjust if needed, the overall physical flatness of the print bed.
Napsal : 04/12/2020 5:39 pm
@jsw 7x7 in my view the way to go.  3x3 has too large of gaps in my opinion.
Napsal : 04/12/2020 6:41 pm
jsw
 jsw
(@jsw)
Posted by: @cwbullet
That's what I use (7x7), and if anything it helps.  Less than a minute of time is minor compared to the total print time of most prints.  However, I don't think that it is a magic bullet, particularly when other more significant factors exist.
Napsal : 04/12/2020 6:47 pm
@jsw
I could have been more clear.  I was trying to agree with you.
Napsal : 04/12/2020 7:01 pm
thedevilsjester
(@thedevilsjester)
I will definitely try these, the Nyloc mod, with the 7x7 and see if I can get back to having my MK3s being reliable.  Any idea why (or how) a bed could start to go quite a bit out of level?
Napsal : 04/12/2020 7:29 pm
