PLA loading, PETG not
3DWillem
(@3dwillem)
I have the MMU2S installed. PLA is working ok. It is loading and can print in all positions.
If I load PETG into the same position as PLA it wont load into the nozzle.
There is no friction in the PETG path. I also removed 20 cm from the filament to be sure
it is a clean and sharp start.
After selecting loading into nozzle the filament is sometimes 5 cm out of the selector.
Checked the grip of the bearings and saw no problems.
Any clues in this?
Opublikowany : 21/10/2019 7:47 am
Daniel B
(@daniel-b-2)
RE: PLA loading, PETG not
Did you get this resolved?  I have the same problem.
After PETG got stuck in the PTFE tube and got that cleaned out I can't load PETG anymore. PLA works fine.
Opublikowany : 05/04/2020 3:29 am
