Pinda probe issue after upgrading?
I am having issues calibrating my printer after upgrading to the mmu2s.
When I try to calibrate my xyz I set the extruder to the top, then click ok and it flinches, then tells me it failed.
When I go to "show endstops" the z position keeps switching between 0 and 1. I pulled the pinda off the extruder carriage and it still shows the same result. Before ordering a replacement is there anything else I can try?
Napsal : 11/10/2021 9:50 pm
Topic starter
answered:
please help?
Does anyone here have any advice?
Napsal : 12/10/2021 3:30 pm
Try this
I often have problems with XYZ calibration failures if my extruder is positioned near and end stop when I start the process. Position the extruder mid way between all the stops (~center of print volume in all three axis) and try again.
Napsal : 12/10/2021 5:16 pm
