No Printer in Slic3r
Thomas
(@thomas-12)
Hello dear forum. I have bought a MMU 2 bought and want to print now, of course. Here are some questions:
* I have installed the version 1.41.0 and have only the printer Original Prusa I3 Mk3 to choose from. So no MMU2. W can I find this.
* Where can I make the selection with which filament I would like to print. In the settings, I select the extruder, in the print settings under "Multiple extruder" then what he should take. But the printer always takes filament 1.
I ask for help. Thank you in advance...
Opublikowany : 10/10/2018 10:10 am
Lichtjaeger
(@lichtjaeger)
Re: No Printer in Slic3r
To add the MMU go to `Configuration -> Configuration Wizard...` and check the MMU 0.4 Nozzle.
To choose an extruder/filament double-click the corresponding object. In this window, you can select an extruder for each separate part of your model.
Opublikowany : 10/10/2018 11:09 am
