Modification of the length of the PTFE tube MMU / Extruder
x.lhermitte
(@x-lhermitte)
For accessibility reasons, I changed the position of the MMU on my printer, and I had to replace the original tube which goes from the MMU to the extruder with another one a little longer.
But this causes a problem : when loading the filament, it no longer goes to the extruder and stops before.
So I would need that the MMU pushes the filament a little longer, so that it reaches the extruder ...
Can I configure this information? I want that the filament is pushing longer or on a longer distance.
Thank you very much, for the informations that you can give me on this subject.
Excuse my rough english.
Xavier
Ce sujet a été modifié il y a 6 years par x.lhermitte
Publié : 11/04/2020 8:45 pm
Agkirk
(@agkirk)
RE: Modification of the length of the PTFE tube MMU / Extruder
This link might be helpful.  https://help.prusa3d.com/en/article/factory-reset-mmu2s_1920/
The PTFE length is re-calculated in other places.  I think it was the Self Test.
Publié : 01/05/2020 6:32 pm
Posted by: @x-lhermitte
Xavier
If you have a MK3 you have to calibrate the length, see here:
https://help.prusa3d.com/en/guide/service-menu-individual-filament-calibration_86376
With the S Upgrade this is no longer absolutely necessary.
Publié : 01/05/2020 6:44 pm
