MMU2S with MK2.5S idler drum rehoming on filament unload
New issue has popped up. On the first filament change the ramming happens normally. The moment the MMU2 motor turns to unload the filament all of the lights start flashing and the idler drum re-homes. Due to this delay in unloading the filament gets stuck in the extruder. I have to manually pull out the filament. The print then continues and is fine for the rest of the print. No other issues with unloaded.
Any suggestions?
I am running 3.7.2 firmware on the MK2.5S and 1.06 firmware on the MMU2S.
Veröffentlicht : 11/11/2019 7:05 pm
