MMU2S tune nozzle temperature and speed on the fly.
JKeay
(@jkeay)
I wonder where is the best place to put new wish-list firmware features?
I notice that tune nozzle temperature while printing doesn't really work on the MMU2S (firmware 1.0.5 & 3.7.0 MK3S). The override happens but is not remembered when the printer returns to the overridden extruder. There appears to be a similar issue if you dial back the speed during the print (you end up quickly back at 100%).
I was trying to raise the soluble filament temperature a little. Verbatim BVOH has 200-220C on the box, but only 195C in the default slicer settings and I was getting lots of MMU load issues when intermixed with 205C PLA (PLA x 5 worked fine).
Este debate ha sido modificado el hace 7 years por JKeay
Respondido : 25/04/2019 10:17 pm
3Delight
(@3delight)
Moderador Moderator
RE: MMU2S tune nozzle temperature and speed on the fly.
I would suggest over on the GitHub site for Slic3rPE: https://github.com/prusa3d
This is a user to user forum and nobody from Prusa looks on here very often.
Respondido : 25/04/2019 11:06 pm
vintagepc
(@vintagepc)
Miembro
I'm betting it's a side effect of filament switching; each change it will need to reset the temps etc to the settings of the new filament; a one filament print doesn't do this, so it will stick for the rest of the print.
Respondido : 26/04/2019 12:58 am
