MMU2S single mode select filament on printer
salautom
(@salautom)
Hello,
is there a possibility in the software to preselect the filament in single mode?
I tried already with double click on part, select part and select extruder, but when printing (via octoprint) I always have to walk to the printer to select the filament number, very annoying
best regards,
Henk
Publié : 15/05/2019 9:38 pm
gnat
 gnat
(@gnat)
RE: MMU2S single mode select filament on printer
If you are using Slic3r there is a "MMU2 Single" profile option you can add. That automatically selects tool 1 and prints from there.
MMU tips and troubleshooting
Publié : 15/05/2019 9:45 pm
jsada.xyz
(@jsada-xyz)
What I do in those cases is configure the gcode as MMU and select the spool I want to use (doble click in the part) so the printer selects directly the filament I set in slic3r.
salautom
(@salautom)
I select as Printer: Original Prusa i# MK3S MMU2S Single
is that the profile I have to select?
Publié : 15/05/2019 9:51 pm
gnat
 gnat
(@gnat)
Yeap that's the one. If you slice with that profile it should automatically select tool 1 and print from there for you.
At least that's how it worked for me.
Publié : 15/05/2019 10:05 pm
salautom
(@salautom)
no, is not working for me, the printer is asking on the display for the filament number...
Publié : 15/05/2019 10:07 pm
RakNoel
(@raknoel)
MMU2 single will add the gcode commands "Tx", "Tc" and last "M702 C". These are used to ask for which to load, use and unload. If you want to load a specific T0-T9 can be used.
But you could just slice as a multicolor using only 1 color. That will load perfectly fine only the first extruder.
Publié : 16/05/2019 1:28 am
salautom
(@salautom)
Posted by: RakNoel
now I use multicolor with 1 color and that is the way it works for me, thanks
Publié : 19/05/2019 11:45 am
