MMU2S Selector motor not mooving after firmware update
Hello! First, note that few minutes before I update the firmware of the the MMU2S , step motor was working fine. Then now it tell me to verify the motor is not blocked. Which is not! I can hear the step motor working but nothing move. And if I shut off everything, I can manually move it. I have tried many things but still no go..
Any clue?
PS My printer is a i3 MK3S
Thanks!!
Opublikowany : 09/10/2024 5:15 pm
RE: MMU2S Selector motor not mooving after firmware update
You should check the firmware settings for any motor calibration options and if necessary, reinstall the firmware to see if that resolves the issue.
Opublikowany : 14/04/2025 7:14 am
