[Risolto] MMU2s not recognised any more from MK3S
Rob
 Rob
(@rob-16)
Hi all
I have setup the MK3s with a MMU2s, eveything works fine.
I have printed many parts, suddenly, out of the blue the MK3S tells me that the gcode ist not for this printer version. I checked the menue and MK3S tells me that no MMU2 is available.
The first time I did an update of the firmware MK3S and it worked like a charm.
Now, a couple of days later the same issue again. between two prints, just finished the first print I added another print with Octoprint to the MK3S with MMU2 in single mode and the printer tells me that the gcode which i printed before is not valid. No MMU2 available.
I will update the firmware again but this behavior is strange.
cheers
Robd
Postato : 03/12/2019 6:40 pm
Rob
 Rob
(@rob-16)
RE: MMU2s not recognised any more from MK3S
OK, seems to be solved. Somehow Octoprint lost the configuration which I did not check.
Setup Octoprint,  in the printer profile i entered four extruders and ticked the shared nozzle box.
Itś now working again.
Postato : 06/12/2019 12:07 pm
MechLink
(@mechlink)
@robd
good to hear
See my stuff at
https://www.printables.com/@MechLink
https://www.myminifactory.com/users/MechLink
Postato : 06/12/2019 3:30 pm
