MMU2 stuck after unload with firmwares 3.9.0 + 1.0.6
Myrecek
(@myrecek)
After my Mk3S+MMU2S firmware update (3.8.1+1.06 -> 3.9.0+1.06), MMU sometimes behaves strange:
On filament unload, extruder stepper seems to stay enabled and MMU is not able to pull the filament out. When I press the MMU2 middle button to try to fix the issue, MMU2 steppers do not move. They do not even move after reset (the X button). They start working again after switching the printer off and on.
Tried to flash the firmware again, also tried MMU2 factory reset. The problem persisted.
I downgraded the printer firmware back to 3.8.1 (kept MMU 1.0.6 as it had already been there before). The problem did not occur again
Napsal : 27/05/2020 5:01 pm
1 lidem se líbí
BOFH 1337
(@bofh-1337)
RE: MMU2 stuck after unload with firmwares 3.9.0 + 1.0.6
I got the exactly same problem. Also all 5 LEDs start flashing randomly on a start of a print. I then have to power-cycle it to get it back in a working state. I will try downgrading and see if that works for me too.
Napsal : 28/05/2020 5:05 am
A Company that Makes Everything™
(@a-company-that-makes-everything)
After the current firmware upgrade, when trying to print the first layer calibration, I just get a blob as referenced in this reddit thread.
https://www.reddit.com/r/prusa3d/comments/d0xlxp/prusa_i3_mk3s_mmu2s_printer_wont_print_just_keeps/ezfnp94/
I tried flashing both firmware's again. They complete successfully but I get the same behavior.
Something seems off in this firmware update...
Thanks,
Timothy
Napsal : 07/06/2020 11:08 pm
