MMU2 on MK3 Malfunctioning After Firmware Update
My MMU2 on the MK3 is not working properly.
I checked the connections inside the MMU as suggested, but things got worse.
After trying to update the firmware, the device keeps crashing—what should I try next?
AdinaAJackson Are you ready to jump with blocky blast
Respondido : 28/05/2025 3:32 pm
RE: MMU2 on MK3 Malfunctioning After Firmware Update
Update both the printer firmware and the MMU. Remember the order is important. Always update the main printer firmware (MK3) first, then the MMU2 firmware. Make sure you are using the correct `.hex` file for your specific MK3 model (MK3S/MK3S+) and MMU2S. This is probably the easiest way to do it.
The future is printed google doodle baseball, one layer at a time
Respondido : 26/06/2025 3:38 am
