MMU2 Firmware Update Error - Could not open port: COM7
Morgan Lee
(@morgan-lee)
Mitglied
Hi. I am fairly new to 3D printing and got a used MK3S with MMU2. It hasn't been used in several years so the firmware is very out of date. I was able to update the printer firmware just fine but when I try and update the MMU firmware I keep getting this error:
avrdude-slic3r -v -p atmega2560 -c wiring -P COM7 -b 115200 -D -U flash:w:0:C:\Users\mlee2\Downloads\prusa3d_fw_3_8_0_MK3S_1_0_6_MMU2S\prusa3d_fw_MK3S_3_8_0_2684.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Dec 12 2023 at 15:27:27 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
Using Port : COM7 Using Programmer : wiring Overriding Baud Rate : 115200avrdude-slic3r: ser_send(): write error: The semaphore timeout period has expired.
avrdude-slic3r: stk500v2_send(): failed to send command to serial portavrdude-slic3r: stk500v2_getsync(): can't communicate with deviceavrdude-slic3r: Could not open port: COM7
If anyone has any suggestions they would be much appreciated!
Dieses Thema wurde geändert Vor 2 years 2 mal von Morgan Lee
Veröffentlicht : 15/02/2024 5:19 pm
RE: MMU2 Firmware Update Error - Could not open port: COM7
Are you using prusa slicer as the programmer?
Veröffentlicht : 15/02/2024 5:46 pm
Morgan Lee
(@morgan-lee)
Mitglied
Yes I am using prusa slicer
Veröffentlicht : 15/02/2024 5:55 pm
Are you sure Com7 is the correct port?
Veröffentlicht : 15/02/2024 6:50 pm
Hello
(@hello)
Hmm what id recomed doing is installing arduino ide then go tools port then see what ports are there 1 and 3 are default so leave them but the one thats not 1 and 3 is the right one.  Then go to prusa slicer and chose that com port.
Veröffentlicht : 16/02/2024 3:16 am
Hello
(@hello)
Also forgot to mention the printer is on and the mmu has power right
Veröffentlicht : 16/02/2024 3:18 am
Morgan Lee
(@morgan-lee)
Mitglied
That seems to have worked. Thank you!
Veröffentlicht : 16/02/2024 5:23 pm
Hello
(@hello)
Posted by: @morgan-lee
Yep you had com ghosting. All good.
Veröffentlicht : 17/02/2024 8:12 am
