MMU2 board flash failed
ad.lamy
(@ad-lamy)
Has anyone tried to flash the MMU2 board with the fw 0.9.0 provided together with the last 3.4.1 Einsy fw ?
I get an error and it won't install.
Einsy fw 3.4.1 installed first with no problems.
Using Slic3rPE-1.41.1-rc+linux64 and micro usb between board and PC.
Slic3rPE log
avrdude: Version 6.3-20160220-prusa3d, compiled on Oct 5 2018 at 15:41:54
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/tmp/.mount_Slic3roqlBaQ/usr/bin/resources/avrdude/avrdude.conf"
Using Port : /dev/ttyACM0
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as CB
avrdude: reading input file "/home/andre/Desktop/prusa3d_fw_MMU2board_0_9_0.hex"
avrdude: writing flash (17286 bytes):
Writing | ##########avrdude: error: programmer did not respond to command: set addr
avrdude: error: programmer did not respond to command: write block
# ***failed;
####################################### | 100% 0.56s
avrdude: failed to write flash memory, rc=-1
avrdude: safemode: Verify error - unable to read lfuse properly. Programmer may not be reliable.
avrdude: safemode: Sorry, reading back fuses was unreliable. I have given up and exited programming mode
avrdude: error: programmer did not respond to command: leave prog mode
avrdude done. Thank you.
MK4/MMU3 - VORON 2.4 350 Stealthburner
Postato : 08/10/2018 10:46 pm
ad.lamy
(@ad-lamy)
Re: MMU2 board flash failed
Solved, related with modemmanager package
https://github.com/prusa3d/MM-control-01/blob/master/README.md
Postato : 09/10/2018 11:23 pm
undertakingyou
(@undertakingyou)
I had the same issue and found the modemmanager udev rules that are in the readme fixed the issue. Thanks for noting it here.
Will--
Postato : 15/04/2019 12:00 am
jjfgi1@gmail.com
(@jjfgi1)
RE: MMU2 board flash failed
I had the same problem, editing the file "99-mm.rules" as suggested by @andre-l9 solved it
Postato : 25/04/2019 10:17 pm
