MMU Wipe Tower Speed Control - BVOH/PVA and PLA
Dan H.
(@dan-h)
Is there a way to decrease the speed of the wipe tower. When printing with BVOH or PVA the speeds on the wipe tower are just a bit too fast for good adhesion causing the layers to be "torn" up but the nozzle when it passes over them again. They adhere just fine on the model itself at a slower speed, its the wipe tower thats ultimately causing the prints to fail.
Napsal : 15/05/2019 9:22 pm
2 lidem se líbí
tsamisa
(@tsamisa)
RE: MMU Wipe Tower Speed Control - BVOH/PVA and PLA
I have the same problem with you with PVA (along with loading issues). I reduced the raming speed, volumetric speed of the filament but the problem is still present. You need the higher speeds to limit stringing - i think. I was wondering if instead of printing lines parallel to the ones of the previous layer, change the orientation by 90degrees on every second layer. Maybe then the wipe tower will become more "rigid". I dont know if it can be considered something they can incorporate to prusaslicer
Napsal : 17/05/2019 6:39 am
1 lidem se líbí
toaf
 toaf
(@toaf)
it used to slow itself down. if you look it would say "speed 80%"  using the soluble interface at least. we kept asking how to set that in slicer, but they never said anything more than volumetric speed stuff.
I haven't used soluble interface in awhile.  make sure you make the wipe tower bigger. I think I doubled it.
Napsal : 17/05/2019 6:55 am
kursat.u
(@kursat-u)
Try setting the volumetric speed for that filament. This is how I made it work for
I recall an prusa documentation but can't locate it.
me. http://projects.ttlexceeded.com/3dprinting_calibrating_volumetric_rate.html
Napsal : 09/05/2020 9:54 pm
