MMU Load Failed (MMU2S)
Petkanna
(@petkanna)
So, this happens yesterday, kinda frustrating
and what is the solution? apparently i just need to hit the button to continue, there's no tinkering, no checking for jammed filament, just "press to continue" retry menu.
printer resuming the nozzle temperature, and everything good to go
the error message was "MMU LOAD FAILED"
it is not FINDA NOT TRIGGERING, or PINDA NOT TRIGGERING, or REMOVE OLD FILAMENT
thanks for reading
Opublikowany : 04/08/2024 1:57 am
Petkanna
(@petkanna)
*cannot edit the original post
additional story:
i set up a multi color print with 24hr printing time, and i let it print while i was working nearby for almost 12hr, i can hear the printing sound and everything is okay
then i left the printing to go to sleep, and i check the remaining time (12hr), then in the morning, i was welcomed by the news of MMU LOAD FAILED, with 11.45hr print time remaining (15 minutes after i left????)
on the serious note, if anyone happen to experience the same problem, the first thing you should check is the filament, if there's a jammed / grind / break.
This post was modified 2 years temu by Petkanna
Opublikowany : 04/08/2024 2:13 am
Lourdes Kuhic
(@lourdes-kuhic)
RE: MMU Load Failed (MMU2S)
Why can't you edit the original? Because you've passed the deadline to edit your post. You only have a certain amount of time to edit your post. If you miss it, you can't edit it.
geometry dash deadlocked
Opublikowany : 16/09/2024 6:57 am
erchantconvot
(@erchantconvot)
It turns out it was a broken filament. No wonder my printer keeps giving me an error. Thanks anyway.
subway surfers
Opublikowany : 04/10/2024 2:19 am
