MMU just blinks red lights
jon bondy
(@jon-bondy)
Not sure that this is the right place in the forum for this.
The MMU has worked OK for a few months, but suddenly all of the LEDs blink red immediately after I power up. There is no filament sticking out to impede the slider from moving back and forth, and the slider moves easily when the power is off and I move the threaded rod.
Any suggestions?
Opublikowany : 21/01/2019 10:00 pm
Olef
 Olef
(@olef)
Re: MMU just blinks red lights
Usually means the FINDA is activated, i.e. filament or strings stuck under the steel ball.
Opublikowany : 21/01/2019 10:35 pm
Nikolai
(@nikolai)
FINDA glowing red light -> no filament
FINDA is dark -> filament detected or FINDA doesn't get power
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 21/01/2019 11:48 pm
toaf
 toaf
(@toaf)
maybe your ball is stuck abit. but 100% sounds like finda issue
Opublikowany : 22/01/2019 1:48 am
richard.l
(@richard-l)
Member Moderator
Moved to appropriate forum.
Opublikowany : 22/01/2019 4:05 pm
eschlenz
(@eschlenz)
I 100% agree with the other replies. The FINDA would be the first thing I'd check in you situation.
When I suspect the FINDA, I do the following:
1. Unscrew the bolt that holds the FINDA in place.
2. Remove the FINDA probe.
3. While covering 1/4 of the top hole with a finger, I'll spray air through the front hole. Your finger is there just to prevent the ball from jumping out from the air pressure.
4. Also, blow air in from the top hole.
5. Reinstall the FINDA probe by following the instructions for setting the FINDA height.
Opublikowany : 23/01/2019 2:50 am
jon bondy
(@jon-bondy)
Thanks for all of your comments. I fiddled with the FINDA and blew all of the holes out, and it is working again.
Opublikowany : 24/01/2019 5:40 pm
