MMU 2.0 w/ v.9 firmware won't update
Shawn S
(@shawn-s)
This weekend I finally assembled my MMU 2.0 kit that was delivered with my Mk3 printer a couple months ago. I have downloaded the latest version of everything (prusa drivers/apps package 2.2.2, firmware 3.5.1, MMU firmware 1.0.3). I've updated the printer to 3.5.1 just fine but when I go to update the MMU unit it fails in the following manner:
I connect the USB from the laptop to the MMU and open slicer. I choose update firmware and the dialog shows the MMU COM port selected. I then select the MMU firmware and it removes the COM port drop-down and replaces it with a label that reads "Automatically detected." I then tell it to start the update and it immediately changes to a red label telling me that the MMU is not connected and to press the reset button if it is. Then the MMU seems to go through its startup sequence again. I've also tried using the 1.01 MMU firmware with the same result.
The MMU otherwise appears to function with the v0.9 firmware, I can load filament and print and eject. Is there some other trick I've missed to get this updated?
Publié : 31/12/2018 2:23 pm
Flack
(@flack)
Re: MMU 2.0 w/ v.9 firmware won't update
I had this on my laptop when I went to upgrade the firmware after only doing it yesterday, it failed straight away, no matter what i tried with the printer worked. I had just left the laptop on so it was in sleep mode
But what did work was to unplug the usb from the printer and reboot my laptop, when rebooted plug in the usb lead and then turn on the printer, after this reboot it updated the firmware no problem.
Its like the driver does not release the com port used.
Publié : 31/12/2018 9:41 pm
Shawn S
(@shawn-s)
A complete reboot of everything with never having been connected to the printer appears to have fixed it. MMU is on 1.03 now. Thanks.
Publié : 31/12/2018 10:18 pm
Juan Puchol
(@juan-puchol)
I can't flash my MMU2. Always finish with an error message:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0980
0xff != 0x1f
avrdude: verification error; content mismatch
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as CB
avrdude: safemode: Fuses OK (E:CB, H:D8, L:FF)
avrdude done. Thank you.
It doesn't matter which firmware I use, all of them fail. NOw my MMU2 unit is unsuable.
I have tried different cables, to reboot PC and printer, full reset printer, now I have no ideas.
What can I do?
Publié : 04/01/2019 11:10 pm
