MK2.5 and 24 Volt for the mmu
dickie24
(@dickie24)
Is it possible and useful to operate the MMU2 on the MK2.5 with 24 Volt?
I still have a small 24 Volt power supply left and the TMC drivers of the MMU2 should have more possibilities?
dh
Napsal : 04/02/2019 9:32 am
Re: MK2.5 and 24 Volt for the mmu
Hi Dirk,
you would have to use a common ground / 0 volts rail between the two power supplies,
and you would have to isolate the MMU 24 volts from the prusa 12 volts
Napsal : 04/02/2019 12:30 pm
eschlenz
(@eschlenz)
Would swapping in the board from the MK3 be a quicker solution?
Napsal : 04/02/2019 5:51 pm
No.
Einsy uses 5 volt fans, 24 volt heatbed and extruder heater
The 24 volt heatbed does not fit the mk2 y carriage
Napsal : 04/02/2019 6:59 pm
