MK2.5 and 24 Volt for the mmu
Is it possible and useful to operate the MMU2 on the MK2.5 with 24 Volt?
I still have a small 24 Volt power supply left and the TMC drivers of the MMU2 should have more possibilities?
dh
Re: MK2.5 and 24 Volt for the mmu
Hi Dirk,
you would have to use a common ground / 0 volts rail between the two power supplies,
and you would have to isolate the MMU 24 volts from the prusa 12 volts
Would swapping in the board from the MK3 be a quicker solution?
No.
Einsy uses 5 volt fans, 24 volt heatbed and extruder heater
The 24 volt heatbed does not fit the mk2 y carriage
