Max Volumetric Speed Makes No Difference In Wipe Tower?
ben_r_
(@ben_r_)
I am attempting to find a way to eliminate blobs in my wipe/purge tower and I thought I'd try reducing the Max Volumetric Speed for the print. After reducing the setting and re-slicing the effects can be seen for the object, but the purge tower Max Volumetric Speed never changes.
Is there no way control the Max Volumetric Speed for the purge tower? And yes I'm running the latest software/firmware/hardware.
If at first you don't succeed, redefine success!
Posted : 03/06/2020 12:36 am
ben_r_
(@ben_r_)
RE: Max Volumetric Speed Makes No Difference In Wipe Tower?
Hmmm.... Okay, maybe my eyes are going cross-eyed from staring at all these settings, but after restarting PrusaSlicer it appears that the Max Volumetric Speed is getting applied to the wipe tower now. Im not sure what I did different as the setting was applied to both sections in the Print Settings and Filament Settings.
Posted : 03/06/2020 9:26 pm
ben_r_
(@ben_r_)
Nope, nevermind, it's still happening. See the attached pic. That is with the Print Settings and Filament Settings sections set to 5 mm3/s. Those darker orange spots are exactly where I'm getting spattering/blobs in my wipe/purge towers.
This post was modified 6 years ago by ben_r_
Posted : 03/06/2020 9:57 pm
