Is there a way to "tune" the idler?
I updated my firmware at the start of January and ever since I've had problems loading and unloading filament. It mostly works, but frequently slips, and then I need to give it a little nudge to get it going again. Fine enough for single colour prints (sometimes I come back and it's flashing at me that it was unable to unload) but for actual multicolour prints with regular swaps this is a no go.
After much experimentation I've discovered that after turning my printer on and waiting for the idler to home, if I just reach in and give it a push so it rotates one click I no longer have any problem with it, filament loads and unloads quick and easy, and it remains so until I power off and on again, at which point I just need to push it that one click again.
Is there a way to tune the position of the idler? Or am I cursed? It's strange, this is consistent and repeatable for me, but I don't see anyone else complaining.
RE: Is there a way to "tune" the idler?
I have complained extensively in forum posts. My recommendation is to go back to firmware 3.12.2 (1.0.6).
Unfortunately I have other, significantly worse problems with 3.12.2. I'm going to try a frankenfirmware this weekend, see how it likes running 3.14 on the printer with 1.0.6 on the MMU2. Failing that, guess I take initiative and try to fix the bug myself.
After a lot of investigation and experimentation I figured out it was failing because the current supplied to the idler motor had been significantly reduced. When the idler would rotate to select a filament it would frequently skip or slip which is what was actually causing my problem. I created a pull request which restores the currents to their pre-MMU3 values, but I get the feeling this may need more work if the new values are meant for the MMU3 which has more efficient motors.
But hey, if you are having a problem like I was you can pull my fixed branch and build it yourself (or I can put the hex file I built and am using somewhere)
