[Risolto] Idler position problems
MarkE
(@marke)
Hi all,
I’ve got an annoying issue with the idler. If filament 1 is selected the bearing is nowhere near the gear and therefore not placing pressure on the filament to allow the gear to drag it through. However, when filament 1 is selected, the idler is nicely positioned for filament 2 and will grab any filament in the channel, not ideal.
This is a new build and I’m confident all of the parts are in the right places and tight where needed and looser where applicable. Running the latest firmware and have tried a factory reset with no improvement. The idler doesn’t spin to the right position even with the top open so it’s not a drag issue.
Any assistance greatly appreciated.
Postato : 09/10/2020 4:01 pm
pcweber
(@pcweber)
Utenti
RE: Idler position problems
I just read this post, it appears to me that your idler motor is in the wrong position.
Stay safe and healthy, Phil
Postato : 27/10/2020 10:57 am
MarkE
(@marke)
@pcweber
Managed to solve the problem, it was due to a problem with the idler itself which looks to be an artefact of the original print.
I reprinted it and everything now working.
Postato : 27/10/2020 3:35 pm
