How to update firmware?
DougS
(@dougs)
Greetings - How do I update MMU2 firmware?  I see all sorts of docs about 'plug in the cable' and things like 'don't plug both in' but not exactly what cable to connect to a PC to update MMU2, does it update from the printer through slicr just like the printer does at the same time? Or is there more wiring?
Veröffentlicht : 16/10/2020 8:48 pm
RE: How to update firmware?
Posted by: @doug-s6
Connect the PC with the MMU2 (USB cable) and start the PrusaSlicer. The printer must be switched on.
You can find a description here: https://help.prusa3d.com/en/guide/upgrading-the-firmware-original-prusa-i3_24720 (Step 3/4).
The latest firmware for MMU2 (1.0.6) can be found here: https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_9_1_MK3_1_0_6_MMU2.zip
and MMU2S here: https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_9_1_MK3S_1_0_6_MMU2S.zip
Veröffentlicht : 16/10/2020 9:21 pm
bertabach
(@blushandroselip)
Thanks for your answer. It helped me a lot.
Veröffentlicht : 07/11/2020 2:14 am
MC3D-21
(@mc3d-21)
Mitglied
Hello,
I have upgraded/ flashed my i3 MK3s/ MMU2s using 'prusa3d_fw_MK25S_3_9_1_3518_RAMBo13a_en-cz.hex'. Message on the end says that press been successful, but printer seem just stuck. What am I doing wrong?
Thank you for help,
Petr
Veröffentlicht : 05/05/2023 6:03 am
