How to select any other tool besides 1 ..
3pm_3dprints
(@3pm_3dprints)
when your doing a print, how do you select any other tool other then 1 to start the print.
for example i want tool 2 to be bottom layer then color change back to tool 1.  i cant seem to find anywhere that allows to me select which tool starts the print.
Publié : 25/01/2023 11:03 pm
Standard gcode starts with a toolchange to select the first tool required, it assumes that whatever is already loaded, or not, is invalid.
Search for M600 followed on the next line by Tn where n is the tool number - values start from 0.
Publié : 26/01/2023 10:17 am
3pm_3dprints
(@3pm_3dprints)
RE: How to select any other tool besides 1 ..
Thank you for the response, i was looking for the option in prusa slicer, with the mmu2s...  just learning to use it.
Publié : 26/01/2023 11:24 am
You might get closer to what you're attempting by re-arranging the part order in the right hand pane - drag and drop.
Publié : 26/01/2023 7:15 pm
