G Code option to cut filament after finishing a single filament print?
Could anyone help me with some g code to cut the end of the filament off after a print finishes in single print mode?
The issue is the cooling moves setting doesn't work with a single mode print, and thus, it's always a huge glob that never feeds successfully next time it is loaded. It ends up going through the attempt, fail, attempt, fail, attempt, fail, cut, attempt, success, and I'd rather just prevent that from happening and take care of the nasty end at the end of the print by simply cutting the tip off.
Open to other ideas, but looking to prevent this wasted time every print.
Thanks!
Publié : 18/10/2021 11:11 pm
