G-Code equivalents to menu actions
Craig Trader
(@craig-trader-2)
I use Octoprint as a controller for my Prusa Mk3 + MMU2 (still waiting for the MMU2S upgrade). I would like to write an Octoprint extension to the control tab that run the following menu commands:
  • Load Filament (All, 1, 2, 3, 4, 5).
  • Load to Nozzle (1, 2, 3, 4, 5).
  • Unload Filament.
  • Eject Filament.
  • Select Tool (1, 2, 3, 4, 5).
  • I know that T# manages tool selection. Are there G-Code equivalents for the other menu commands?
    I solve problems, usually with computers ...
    Postato : 02/04/2019 6:48 pm
    Re: G-Code equivalents to menu actions
    Prusa supported: https://github.com/prusa3d/Prusa-Firmware/wiki/Supported-G-codes
    Marlin General (many work): http://marlinfw.org/meta/gcode/
    Postato : 02/04/2019 7:16 pm
    Peel
     Peel
    (@peel)
    M702 Unloads all filaments
    M702 U Unloads all filaments used during print
    M702 C Unloads filament in currently active extruder
    You could also do T2 M702 C Sets tool to 2 (third filament from the left) then unloads.
    Postato : 02/04/2019 11:09 pm
    Aren't command separators required for multiple commands on one line? I seem to recall not having much success until I placed : between commands.
    Postato : 03/04/2019 12:17 am
    Craig Trader
    (@craig-trader-2)
    Thanks for the quick responses!
    - Craig -
    Postato : 03/04/2019 1:56 pm
