Flexible filaments always jam
Simon Derrer
(@simon-derrer)
I just upgraded to a Mk3s MMU2s and I've been having an issue where whenever I try to use a flexible filament it will load it from the multiplexer just fine but the bondtech extruder gears the filament somehow ends up on the wrong side of them and jams completely.  Any advice?
Postato : 20/06/2019 3:37 am
toaf
 toaf
(@toaf)
RE: Flexible filaments always jam
slow loads and ease the tension on the extruder abit
Postato : 20/06/2019 7:26 am
Simon Derrer
(@simon-derrer)
How do I adjust the load speed of the MMU2S? It seems to run at a single speed all the time.
Postato : 20/06/2019 12:39 pm
There is a thread on the Bondtech/motor shaft alignment in the MK3S being off center.  It causes all sorts of issues with flex filament not loading.  Someone has a redesign of the extruder that corrects the offset, too.
Postato : 20/06/2019 3:28 pm
1 persone hanno apprezzato
Simon Derrer
(@simon-derrer)
Could you give me a link to that thread and where I could find the adjusted parts?
Thanks
Postato : 20/06/2019 4:09 pm
Simon Derrer
(@simon-derrer)
Thanks
I'd have to search for it too.
Postato : 20/06/2019 4:22 pm
