Flanged brass inserts
peroberts
(@peroberts)
Does anyone know where I can purchase the 5mm flanged brass inserts for the filament sensor chimney? I realize there are plenty of brass inserts out there, but the flanged 5mm is really hard to find. I live in the US, so that would be preferable but international is Ok too. Thanks for any help.
Opublikowany : 16/09/2022 2:20 am
RE: Flanged brass inserts
I believe it is a Multi Micro insert.
try these if you can't find a US based supplier
https://orballoprinting.com/en/home/223-original-prusa-insert-m5.html
http://www.brasselectricalaccessories.com/c360-brass-multi-micro-inserts.html
https://www.theinsertcompany.com/brass_multi_micro_inserts_for_plastic.php
Opublikowany : 16/09/2022 6:43 am
peroberts
(@peroberts)
Thanks Joan. This is good information. I really appreciate it!
Opublikowany : 16/09/2022 7:25 am
Good luck.
Opublikowany : 16/09/2022 3:58 pm
