FIXED. Trouble with MMU2S profiles in Slic3rPE, there are none
TMH
 TMH
(@tmh)
So, I’ve completed my upgrade to Mk3s and my build of MMU2s.
FW of printer and MMU2s updated successfully. Slic3rPE 1.41.3+win64 installed.
Problem, I open config wiz in Slic3r, select Original Prusa i3 MK3S MMU2S, next, next, finish. Go to look at Printer profiles, nothing has been added. I’ve repeated these steps several times. I’ve uninstalled/reinstalled Slic3r a couple of times, still nothing.
What stupid thing am I doing/not doing?
Thanks.
EDIT. use Slic3r 1.42.0 Alpha1, silly me, I tried to use released software, forgot the MMU2S was still in Beta.
Opublikowany : 17/04/2019 6:36 pm
markus.i2
(@markus-i2)
Re: FIXED. Trouble with MMU2S profiles in Slic3rPE, there are none
I think you're barking up the wrong tree:
But I don't know why it didn't work for you either.
Opublikowany : 17/04/2019 10:34 pm
TMH
 TMH
(@tmh)
Hmmm, I hate mysteries. The Alpha version was suggested to me by Chat support.
It’d be nice if someone chimed in with a suggestion.
Ah well, at least the machines working and I can finally do some test prints.
Thanks for your response!
Opublikowany : 17/04/2019 11:34 pm
