Firmware problem MMU2s
When the selector block fails to find the correct station, the filament will be extruded from a hole not covered by the block. IE: selector is at station 5 filament comes from 3. The machine asks that the filament be cleared and on doing that attempts to load the correct one - Filament 3. However - it does not ensure the extruder block is at the right temperature first - which can result in a jam if the filament enters the block as it is cooling. This needs to be corrected in the firmware.
Opublikowany : 07/10/2019 7:02 pm
RE: Firmware problem MMU2s
Please try to reproduce this issue and post it on github as an issue.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 07/10/2019 9:55 pm
