FIRMWARE 3.13.2 update on MMU2 old programs do not run anymore
blatti
(@blatti)
Hi  there,
Why I did the update: the MMU2 did occasionally silly things. I did ask me that filament change is correct and did not continue correctly. But I did not do anything with changing.
Now the printer do not want to print the older sliced programs anymore? Does anybody else come across this issue?
After the update: It is sliced for different printer - continue yes / no. And than it does not feed the filament anymore.
The MMU2 update did also have the update for the printer? First printer second MMU2 - am I right? On the MK3S+ I did run another update which went to the center and made temperature tests.
how to overcome?
Put the previous version back in?
thanks a lot
Best Answer by blatti:
too easy - during installation it switched it off. Thanks a lot
if you can imagine it - if you can design it - you should print it!
Make the impossible - possible!
Postato : 05/11/2023 7:15 pm
BaconFase
(@baconfase)
RE: FIRMWARE 3.13.2 update on MMU2 old programs do not run anymore
Did you change the MMU setting from Off to On in the MK3 LCD menu?
The new firmware lets you turn the MMU on/off so you can use the MK3 as if the MMU wasn't installed at all and this setting is Off by default.
XL-5T, MK3S MMU3 || GUIDE: How to print with multiple-nozzlesizes do read updated replies || PrusaSlicer Fork with multi-nozzlesize freedom || How Feasible is Printing PETG for PLA supports on XL very
Postato : 06/11/2023 3:47 am
ITKosta29 hanno apprezzato
blatti
(@blatti)
Postato : 06/11/2023 8:29 am
