Filament selection at start of print
ToastedSheep
(@toastedsheep)
I have just downloaded and installed Slic3r 1.41.3+ and have an issue where if I slice a part using MMU single profile I no longer get the option to select which filament i want to use after the level bed calibration. The printer just starts on it path of printing when it has not even selected and loaded a filament into the extruder.
Any ideas what I am doing wrong? it always used to work before I upgraded to this version, perhaps i should go back to the older version I was using
Napsal : 22/02/2019 4:05 pm
Jorge S
(@jorge-s)
Re: Filament selection at start of print
Hi
I don't believe you are doing anything wrong - I had the same experience with the newer firmware.
Jorge
Napsal : 22/02/2019 5:47 pm
PeterT
(@petert)
I’m also running into this.
Napsal : 22/03/2019 6:06 am
toaf
 toaf
(@toaf)
I know its working in the alpha 7. it now selects filament before warming up.
Napsal : 22/03/2019 6:39 am
Pontalunatic
(@pontalunatic)
Same experience. The next time it kicks in. I've just been aborting the print and starting over.
Napsal : 22/03/2019 5:52 pm
toaf
 toaf
(@toaf)
in the new beta, it works . just tested.
Napsal : 22/03/2019 7:38 pm
