Filament selection at start of print
I have just downloaded and installed Slic3r 1.41.3+ and have an issue where if I slice a part using MMU single profile I no longer get the option to select which filament i want to use after the level bed calibration. The printer just starts on it path of printing when it has not even selected and loaded a filament into the extruder.
Any ideas what I am doing wrong? it always used to work before I upgraded to this version, perhaps i should go back to the older version I was using
Re: Filament selection at start of print
Hi
I don't believe you are doing anything wrong - I had the same experience with the newer firmware.
Jorge
I’m also running into this.
I know its working in the alpha 7. it now selects filament before warming up.
Same experience. The next time it kicks in. I've just been aborting the print and starting over.
in the new beta, it works . just tested.
