Extruder unloads filament after filament sensor gets triggered
[Solved] Extruder unloads filament after filament sensor gets triggered
Lawrence
(@lawrence-2)
So, I just got my MK3S+ kit a couple of days ago, after I built it, fixed a couple of issues and flashed the firmware, I am now stuck.
The problem occurs when the filament sensor gets activated because for some reason the extruder just retracts the filament and this continues until you stop the filament load.
I also checked if the sensors return the correct values.
Best Answer by cwbullet:
I would loosen the screw that mounts the sensor.
Posted : 10/09/2022 9:11 am
RE: Extruder unloads filament after filament sensor gets triggered
Posted : 10/09/2022 1:39 pm
What happens if you temporarily disable the sensor (LCD menu)?
Cheerio
Posted : 10/09/2022 2:50 pm
Lawrence
(@lawrence-2)
Thanks for your advice! But the screw is as much loosened as possible.
Posted : 12/09/2022 11:13 am
Lawrence
(@lawrence-2)
Posted by: @lawrence-2
oh, i missunderstood what screw you meant and i gotta test this but I think you are right @cwbullet
Posted : 12/09/2022 11:24 am
Lawrence
(@lawrence-2)
Thanks a lot! I was getting very frustrated.
Posted : 12/09/2022 11:37 am
singultus
(@singultus)
IMHO this is the same problem as here, see the solution that worked for me there. I'm not fully convinced that this will be solved by screw tension alone.
Cheers Tom
Posted : 06/10/2022 8:56 pm
