Extruder motor not working and is not detected with the initial full testing
I had to unmount the extruder to unclog it and then I mounted back.
But since this operation, the extruder motor is not hot compared to other motors (I don't know if it normal) and does not capture the filament. And this issue is not detected when running the first compete check...
Thank you for your help
Opublikowany : 07/07/2019 2:19 pm
RE: Extruder motor not working and is not detected with the initial full testing
Run a Self-Test.
Opublikowany : 07/07/2019 10:08 pm
