Cut on filament change
I've still a lot of problem with complex models that needs a lot of filament changes.
The major issue is the drop formed end of the filament, when pulled out of the extruder. Since 3.9 the cut feature is working from the menu.
Can I activate this on any filament change, e.g. each time the filament is pulled out, it's cutted by 10mm ?
i3 MK3S with MMU2S
Respondido : 14/07/2020 3:15 pm
1 les gusta
RE: Cut on filament change
I would like this as well.
Respondido : 14/07/2020 6:38 pm
