Cleaning textured pulleys
Matt P
(@matt-p)
After Filament load problems the teeth on the lower textured pulleys now have a some filament bits in them.
What's the best way to clean them out?
Some sort of brush?  Qtips (small threads may be a problem)
Thanks!
Posted : 25/05/2019 6:08 pm
RE: Cleaning textured pulleys
Prusa has a blog post on this:  took all of three seconds to find.
https://help.prusa3d.com/article/3EMxwPQU0B-bondtech-extruder-gears
Posted : 25/05/2019 6:39 pm
Matt P
(@matt-p)
Ah, link is for the Extruder, not the MMU "pulley" but it's kinda the same.
Wasn't sure what to call them, but the install guide just says "Pulley"
https://manual.prusa3d.com/Guide/5.+Pulley+body+assembly/1040?lang=en
Step 5
Link is mostly about the bearings and lubrication,  the MMU Pully doesn't have bearings...    there's a photo of what looks like a small paintbrush.
One of the other links is better.
https://help.prusa3d.com/article/sVQHD6vtfm-bearings-maintenance
The Extruder section mentions brass brush or toothpick  this is what I was looking for.   Wasn't sure what was ok to use on them
 Thanks for pointing me toward the help/maintenance section.
Posted : 25/05/2019 6:56 pm
A stiff nylon brush is the recommended tool; but I've found they don't always get the bits out of the teeth. Instead, I use a brass brush you'd normally use in a Dremel - but manually to avoid polishing off the sharp teeth.
Posted : 26/05/2019 4:24 pm
