Choosing extruders on PrusaSlicer
lberstein
(@lberstein)
Hello everyone. This might be a very silly question, but I've been struggling for hours and feel really stupid. When using Slic3r PE I was able to add an .stl object, then add more .stl's as "parts" so they would retain position and not be placed flat on the bed. Then I was able to easily assign a different extruder to each part, and slice away.
Today I'm finally switching to Prusa Slicer. I can add an object, then add more as parts. Everything is displayed correctly, but there is no way to assign the extruders. If I right click, ALL the object is immediately selected, instead of each individual part. So I can only assign one extruder (the same) to all parts.
If I add each part as a different object I can then assign different extruders, but each part is placed against the bed instead of lined up with all the others.
Please help, I'm feeling very frustrated.
Respondido : 17/07/2019 7:03 pm
RE: Choosing extruders on PrusaSlicer
To select extruder, highlight the part you want to change in the right hand window, in this case, part 5 (Bottom of lightning strike)
click on the extruder choice a couple of times,,, then you should be able to select the preferred extruder
if you have multiple copies of the same item, this will change them all, note I have left and right hand models on the same build plate, so I have to select extruder for all parts in one left hand model, and all parts in one right hand model, to complete the extruder selection
Respondido : 18/07/2019 12:23 am
2 les gusta
lberstein
(@lberstein)
Thank you!!!! It was so simple, and yet so counterintuitive.
Respondido : 18/07/2019 12:46 am
😀 agreed!
Joan
Respondido : 18/07/2019 9:38 pm
1 les gusta
fagnerock20
(@fagnerock20)
Posted by: joan.t
😀 agreed!
Joan
Hi joantabb,
How to change color (extruder) on a simple unique part object? Just changing the color based on the layer?
Respondido : 07/08/2019 4:01 am
Respondido : 07/08/2019 9:39 am
stephen.h14
(@stephen-h14)
Posted by: Tim
Will that change the MMU to a different filament or just prompt the user to change filaments in the current selection? I thought the plus sign just added the M600 at that layer?
Respondido : 07/08/2019 10:10 pm
yes that will invoke M600 filament change
Joan
i did a write up, in this post https://forum.prusa3d.com/forum/original-prusa-i3-mk2.5s-mk2.5-how-do-i-print-this-printing-help/color-swap-by-layer-within-app-slicer-2-0/#post-157469
Respondido : 07/08/2019 10:24 pm
