Change size of wipe tower or increase purge amount
Stevester
(@stevester)
Is there a way in Slic3r PE that you can increase the amount of filament that is wiped? I'm having issues where I need one color to be purged a little more than the other between filament changes.
It looks like the only option will be to print infill first to allow a little more purging before printing.
Best Answer by Pixel:
right side above the list of models and their extruder settings is a button called purge settings, there you can set how much volume of filament is going to be purged when loading or uploading
i printed with some white filament and colors recently and tried setting the load purge for white to 100 but that wasnt enough in my case and i would probably go for 200 next time i try it.
Respondido : 11/06/2019 8:37 pm
Pixel
(@pixel)
RE: Change size of wipe tower or increase purge amount
Respondido : 11/06/2019 8:41 pm
Stevester
(@stevester)
That was it! It seems like that should be located under the "Printer Settings" tab...
Respondido : 12/06/2019 8:55 pm
