BUG: Move Axis may disappear from the LCD menu is an MMU error occours
Antimix
(@antimix)
Hello,
yesterday at the end of the print the MMU2 failed to extract the filament, and went "crazy" not responding with blinking leds.
There was also an error message for attention on LCD. I unscrew the two MMU screws and extracted manually the filament, that was basically free and already out of the extruder. No idea why it was not capable to extract it from the bowden tube till the MMU.
Then  I closed the MMU2 and reinstalled the screws. I pushed the LCD panel button and the message went away.
Then I wanted to move the axes, and I noticed that the Move Axes menu item was disappeared from any menu.
I had to turn off and on the MK3S to get back the menu item in Settings.
It should be a firmware bug.
Regards
Opublikowany : 25/11/2021 5:46 pm
RE: BUG: Move Axis may disappear from the LCD menu is an MMU error occours
Bugs are usually placed on Github:
https://github.com/prusa3d/Prusa-Firmware/issues/
Opublikowany : 02/12/2021 10:13 am
