0.1mm Nozzle bridging over solid infill
When I use my 0.1mm nozzle it tries to bridge over solid infill. The bridge is way too thin, resulting in problems. Setting the Bridge Flow Rate to 1 helps, EXCEPT now my purge block is still bridging... Is there anyway to change the settings for the purge block extrusion? I think this might be a bug...
Napsal : 28/07/2019 3:49 pm
Topic starter
answered:
RE: 0.1mm Nozzle bridging over solid infill
Napsal : 31/07/2019 12:34 am
