We need a MMU Chess Set
Eddiie
(@eddiie)
Cant believe someone has not made a MMU chess set (not counting the Minions set!).
Before I attempt to meshmix a set (which may never get finished), has anyone else started this work already or posted somewhere?
Opublikowany : 19/06/2019 2:21 am
RE: We need a MMU Chess Set
https://www.thingiverse.com/thing:3296129
This post was modified 7 years temu 2 times by --
Opublikowany : 19/06/2019 5:16 am
Eddiie
(@eddiie)
Thank you for that but I was referring to the chess pieces themselves.
Opublikowany : 19/06/2019 6:05 pm
Ah - the pieces are all individual and  easily modified for multi-color printing.  Except for maybe the King - I think I messed it up ... lol. Chess_mixes
This post was modified 7 years temu by --
Opublikowany : 19/06/2019 6:15 pm
Eddiie
(@eddiie)
ohhh I see now.   You made these in Meshmixer, which is what I was planning to use to tweak the models.    Cool.   I'll check it out.
Thanks!
Opublikowany : 19/06/2019 6:19 pm
ea69
 ea69
(@ea69)
I stopped working on the minions set as I could not get the results I wanted within the 4 colors per layer limit of the Palette 2 and had a horrible experience with the original MMU2.
Now that I am getting good results on the MK3S/MMU2S, I have started working on the set again. Most everything I want to do can be done with the additional filament the Prusa solution provides.
Just finished printing the pawn and rook on the MMU2S and they came out great. The knight and bishop models were mostly done when I  stopped, so I should be able to complete them reasonably quickly.
Opublikowany : 19/06/2019 7:08 pm
1 ludzie polubili
