Use purge Block to adjust Purging volumes
Jonathan Kayne
(@jonathan-kayne)
Hi all,
I was wondering if there was a way to figure out what purging volumes could be adjusted in Slic3r PE by using the Purge Block as a basis for this.
I would prefer to use a reliable method to figure this out rather than simply tweak the settings and hope they work. Maybe someone could make a gcode file that allows you to figure this out.
I was more on the idea that you could take your purge block and measure the transition to get the volume actually needed.
Any thoughts?
-Jonathan
Jonathan Kayne, KM4CFT
Virginia Tech Class of 2021 - Electrical EngineeringCreator of the CFT1 Transceiver"I am always thinking about making. My future begins when I wake up and see the light." - Miles Davis
Opublikowany : 04/11/2018 11:59 pm
nuroo
(@nuroo)
Re: Use purge Block to adjust Purging volumes
https://www.thingiverse.com/thing:3120233
By Mr. Paul Meyer
goto purging volumes.....
and watch this video:
Prusa MK3 > MK4s
Prusa MK2.5 kit > MK3 > MK3s > MK4s
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6 - taken apart for space
CR10s4 - upgrading
Delta 3ku - dont use
Opublikowany : 05/11/2018 12:16 am
toaf
 toaf
(@toaf)
peter.122 has some calibration cubes also
https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f53/purge-calibration-towers-t24562.html#p108045
Opublikowany : 05/11/2018 12:52 am
