Time to get busy!
Pagina 1 / 2
Time to get busy!
The race is on...
ordered my mmu1 upgrade oct 2017,
received it late 2018...
will I get it working before 2019....
started assembly this morning...
Who mentioned Brinksmanship!
Joan
Postato : 31/12/2018 7:52 pm
Nikolai
(@nikolai)
Re: Time to get busy!
Go joan, go! Good luck and take your time.
Stop answering posts in Facebook might also help 😉
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 31/12/2018 7:57 pm
J
Postato : 31/12/2018 8:30 pm
toaf
 toaf
(@toaf)
good luck Joan, fear not, the 5 pound bag of gummy bears I got for my install was way more than needed.
Postato : 31/12/2018 11:34 pm
Would you believe?
ok...
Postato : 01/01/2019 12:59 am
Happy new year!
Postato : 01/01/2019 1:00 am
Nikolai
(@nikolai)
Would you believe?
Always 😀 Happy New Year!!!
Often linked posts:
Real Multi Material
Postato : 01/01/2019 1:08 am
nearly got there, at least I got a test print out of the MMU before midnight...
the name tag was off my mmu1
Joan
Postato : 01/01/2019 1:11 am
toaf
 toaf
(@toaf)
try for new year central time zone 😀
glad to hear you "got busy" on new years
Postato : 01/01/2019 1:18 am
that's cheating
GMT here
Postato : 01/01/2019 1:26 am
toaf
 toaf
(@toaf)
ok a compromise "West Greenland Standard Time" for the win -3 😀
Postato : 01/01/2019 1:31 am
toaf
 toaf
(@toaf)
how goes the battle Joan?
Postato : 01/01/2019 7:33 pm
losing at moment... I am unable to adjust the filament feed for the 5 filaments, either I am faulty, and can't manage the mmu buttons, or the sequence has changed
Joan
Postato : 01/01/2019 7:37 pm
toaf
 toaf
(@toaf)
I do think its possible it changed abit. I have not updated to the latest mmu2 firmware. but make sure you use the correct button to choose number 4 (if it hasn't changed)
Postato : 01/01/2019 7:47 pm
toaf
 toaf
(@toaf)
I don't think its changed.
https://manual.prusa3d.com/Guide/Service+menu+-+Individual+Filament+Calibration/842
it is an odd one to do with the barbaric interface. (UP, UP, DOWN, DOWN, LEFT, RIGHT, LEFT, RIGHT, B, A, START) that will let you try 30 more times 😀
short version of how I remember it (I cant do it now im printing)
get into service mode (it does it's happy dance twice) when you have the 1 and 5 lights use left or right to move to number 4 light. hit the middle button. then move the left and right buttons to pick the filament you want to do. hit the middle button it should do a default length. then use the left and right arrows to get the length you want.
if the calibrations seems to change often (that's why they have you do it 3 times) check your filament path.
Postato : 01/01/2019 7:59 pm
toaf
 toaf
(@toaf)
the nylon idler assembly I printed works. and it felt really cool. I still don't know why my last one broke. 100% didn't do anything wrong.
but I used glue..ii never use glue
Postato : 01/01/2019 8:00 pm
Today is the 5th January, overnight I completed this print
[attachment=0]20190105_082119[1].jpg[/attachment]
it's taken 4 days, because I couldn't get into the service menu to adjust the feed length for the five filaments
early issues failed due to filament grinding and aparrent low temperature,
the prusa sliced gcode seemed to have mixed 205C and 210C extrusion which with the filament grinding, didn't work well...
I upped the temperatures to 215C and improved things, but no success,,,
last night I looked at the issue through squinty eyes, and thought, if I can't shorten the filament feed, why not lengthen the bowden tube... and that's what I did... it's not ideal because the feed lengths differ between filaments... but the sheep survived!
waiting for a new control board to arrive, to address the service menu issue!
Joan
Postato : 05/01/2019 10:19 am
toaf
 toaf
(@toaf)
that's great thinking.
that sheep is SOO pink, even the llamasoft guy would be scared.
that is so cool you got yours going. have a gummi bear on me..
Postato : 05/01/2019 10:26 am
toaf
 toaf
(@toaf)
joan, check out this crazy "silk bronze filament" from china.. I think it looks nuts abit of a green sheen that doesn't show up on film.
Postato : 05/01/2019 10:36 am
joreal
(@joreal)
Joan
Hi Joan,
It looks like you have 1 layer skip on black, just below the sheep’s nose.
Postato : 05/01/2019 3:39 pm
Pagina 1 / 2
