teperature change while loading / unloading
Rainer
(@rainer-5)
Hopefully with MMU3, Prusa manages to set correct temperature changes while changing the filament. So far MMU2 is good if you deal with different colors of the same material ( e.. PLA, PETG etc). If you want to use it for different materials (e.g.  PLA and BVOH or PVA), MMU2 is useless, because when changing the filament, the temperature is set immediately to the "new" temperature and the unloading of the "old" filament is done with the wrong temperature. This leads sooner or later to failed prints or at least to manual interventions.
Napsal : 08/04/2023 8:21 pm
1 lidem se líbí
