Suggestions for first print?
Paul Meyer
(@paul-meyer)
Now that it's on it's way (which means a week if my mk3 shipping was any indication), I need to start planning a print and (if needed) buying filament.
Any good suggestions for:
1) Basic test/calibration prints for 2-5 colors?
2) Impressive demo prints for multi-color?
I'll start poking around thingiverse.
Opublikowany : 30/08/2018 12:39 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Suggestions for first print?
You will need to start printing the pre-sliced models before anything else, just to make sure it's working.
On Thingiverse, check out user cipis (roman.t). He has some awesome models 🙂 https://www.thingiverse.com/search?q=cipis&dwh=895b87cc0a3e9b8
Peter
Opublikowany : 30/08/2018 12:50 pm
Peter L
(@peter-l)
Prusa has a page of multi-color prints: https://www.prusa3d.com/multimaterial-prints/
Opublikowany : 30/08/2018 3:51 pm
PJR
 PJR
(@pjr)
Mostly by Roman (cipis) on Thingiverse 🙂
Peter
Opublikowany : 30/08/2018 3:53 pm
Steve
(@steve-3)
The files that come on the pre-loaded memory card are some good ones.
Benchy is a good test of overhanging and bridging.
The planetary gear is a cool object to show off the capabilities. I usually have to spin it with a power drill to break it in before it runs smoothly.
The bottle opener is a good simple 2 color model. It pauses for you to change colors near the final layers.
The castle is the most detailed object to show off some fine details.
After printing these, go find a few other objects on Thingiverse.
Steve
Opublikowany : 30/08/2018 6:52 pm
PJR
 PJR
(@pjr)
Steve, this is MMU2; there are no files on the memory card for this 🙁
Peter
Opublikowany : 30/08/2018 6:57 pm
imod.systems
(@imod-systems)
Looks like the GCODE is for MMU V1, did they update it for the new MMU V2?
Opublikowany : 31/08/2018 9:54 pm
