Spool Join , different behavior ?
When i first got the MMU2 the spool join work like this Spool 1-2-3-4-5 and after 5 runs out it goes back to Spool 1 and then goes 2-3-4-5 again.
Now it is only using Spool 1-5 and then stops. Which is bad, because with the old way it was easy to just dump nearly empty spools into one colorful print.
Was there a change in the firmware ?
Veröffentlicht : 06/11/2019 8:37 am
